Servisní bulletiny pro 6 MPS
cckl
4
jsem tu nový a pro začátek bych se rád podělil o servisní bulletiny co jsem dal dohromady pro MPSo.
Je to velice užitečné pří hledání/řešení typických závad. Hodně z nich platí i pro 3 MPS nebo CX-7.
Bohužel se mi soubory nepodařilo dát sem na forum, tak přikládám odkaz na ulozto:
Mazda 6 MPS TBS.7z
  • 4106E Emission Recall Campaign.pdf
  • 4807H MIL DTC P2006 Recall.pdf
  • 4907H OBDII Compliance Voluntary Emission Recall Campaign .pdf
  • SA327 TAKATA RECALLS GENERAL INFORMATION PURPOSE.pdf
  • SSP86 Heavy White Exhaust Smoke, Warranty Extension Program.pdf
  • SSP87 Variable Valve Timing Noise and Timing Chain Noise, Warranty Extension Program.pdf
  • 01-002-08 VARIABLE VALVE TIMING (VVT) NOISE WHEN STARTING ENGINE.pdf
  • 01-002-11 Mazdaspeed3 WHITE OR BLUE SMOKE FROM TAIL PIPE AFTER LONG IDLE PERIOD.pdf
  • 01-004-10 WHITE OR BLUE SMOKE FROM TAIL PIPE AFTER LONG IDLE PERIOD.pdf
  • 01-007-09 UNSTABLE IDLING, ENGINE STALLS JUST AFTER STOPPING.pdf
  • 01-008-12 Mazdaspeed3 WHITE OR BLUE SMOKE FROM TAIL PIPE AFTER LONG IDLE PERIOD.pdf
  • 01-009-06 COOLANT LEAK AT RADIATOR SUB-TANK HOSE.pdf
  • 01-010-07 DTC P2006 (VARIABLE SWIRL CONTROL SYSTEM SHUTTER VALVE STUCK CLOSED).pdf
  • 01-010-11 VARIABLE VALVE TIMING (VVT) NOISE WHEN STARTING ENGINE.pdf
  • 01-012-12 VARIABLE VALVE TIMING (VVT) NOISE AND OR TIMING CHAIN NOISE.pdf
  • 01-022-06 FRONT CRANKSHAFT BOLT SERVICE WARNING.pdf
  • 01-022-08 ROUGH IDLE, LACK OF POWER, AND OR MIL ON WITH DTC P2177, P2187 (FUEL SYSTEM LEAN).pdf
  • 01-023-10 DETERMINING EVAPORATIVE SYSTEM LEAK LOCATION FOR DTCs P0441,P0442,P0455,P0456.pdf
  • 01-037-06 MIL COMES ON WITH DTC P2407 (LDP SENSOR ERRATIC).pdf
  • 01-040-07 FRONT CRANKSHAFT BOLT SERVICE WARNING.pdf
  • 01-046-10 Ignition System - MIL ON DTC P0300, P0301-P0304.pdf
  • 01-052-06 MIL ILLUMINATION P0171,P0172,P0441,P0442,P0455,P0456,P2177,P2178,P2187,P2188.pdf
  • 03-001-08 OIL SEEPAGE FROM TRANSFER CASE.pdf
  • 05-003-07 CLUTCH PEDAL IS DIFFICULT TO OPERATE.pdf
  • 08-002-06 AIRBAG (SAS UNIT) REPLACEMENT CAUTION - DTCs B1342, B2477.pdf
  • 09-004-08 TCS, DSC WARNING LIGHT ON WITH DTC C1956.pdf
  • 09-014-06 POWER WINDOW AUTO OPEN,CLOSE AND ANTI-PINCH FEATURES INOPERATIVE .pdf
  • 09-015-08 Keyless Entry - Door, Trunk Request Switch Inoperative.pdf
  • 09-016-08 TRUNK LID REQUEST SWITCH INOPERATIVE - NO DTCs.pdf
  • 09-021-06 INFORMATION DISPLAY DOES NOT ILLUMINATE, CLOCK RUNS FAST IN SUB-ZERO TEMPERATURE.txt
  • 09-022-07 REMOTE KEYLESS ENTRY (RKE) TRANSMITTER SPECIFICATION CHANGE .pdf
  • 09-048-06 2006 MAZDA6, MAZDASPEED6, AND 2007 CX-7 - WINDOWS OPEN UNINTENTIONALLY.pdf
  • MS3-MS6-MPS Service Bulletin v1.00.pdf
  • 2014-08-21 Complaint VVT issue.pdf
Nový člen, každopádně koukám známá Mazda od zdejšího člena ;)
Super data, určitě se to zde neztratí a nejeden klaňák tyto informace ocení. Palec nahoru ;)
