- 260
Shr3ku,
v postupu je 4 bod odpojení minus polu baterie, je myšleno odpojení a poté opět zapojení a bude vše oka ?
Předpokládám že bod 5 je jen pro kontrolu a není potřeba.
Step
Action
1
Switch the ignition ON (engine off).
2
Shift the selector lever to the N position. (ATX)
Shift the shift lever to the neutral position. (MTX)
3
Perform the following work with the brake pedal depressed.
1. Depress the accelerator pedal for 5 s or more.
2. Verify that the charging system warning light and the master warning light flash.
3. Depress and release the accelerator pedal 3 times.
4. Verify that the charging system warning light illuminates and the master warning light turns off.
4
Switch the ignition off and disconnect the negative battery cable. (See NEGATIVE BATTERY CABLE DISCONNECTION/CONNECTION [SKYACTIV-G 1.5, SKYACTIV-G 2.0, SKYACTIV-G 2.5].)
5
Verifying battery condition initialization setting (i-stop setting). (See BATTERY CONDITION INITIALIZATION SETTING (i-stop SETTING) [SKYACTIV-G 1.5, SKYACTIV-G 2.0, SKYACTIV-G 2.5].)
Step
Action
1
2
3
4
5
